exporting archicad layout to autocad
when i saved my plan from layout to autocad model space,it's coming like a block.if i explode,dimensions loose its properties.
is there any solution so that how i can retain it's properties when i saved from project map...
You may need to experiment with two settings in the Save Options panel of the DXF-DWG Translation Setup Dialog: Save Layout Into and Saving Floor Plan fields.
Check the Help file for their description.
