from sketch uo to archicad 13 in a mac
hi im new using archicad, and i need to turn in a school project next week and im tryiting to use some objetcs from sketch up, but i don;t how to import them to archicad, i have a macbbok with archicad 13 and sketch up 7
can somebody hel me,
i need to import from sketch to archicad
2 Replies 2
You can download the Google Earth Add-On. It imports SketchUp files as well.
But I am not sure if it works with SketchUp 7 or only with an earlier SketchUp version. You will have to try.
http://www.graphisoft.com/products/archicad/addons/google_earth/ge_earth_connections_download.html
Edit: Actually, this Add-ON is only available on Windows.
As far as I remember Google did not provide the necessary environment so no ArchiCAD Add-On could be made on the Mac platform.
Mac users without any access to Windows have to export as 3DS (e.g.) from SketchUp and use the 3DS Import add-on (download from the AC Help menu) to import that file. Only SketchUp Pro can export as 3DS though.
There may be some skp-to-3ds converters out there somewhere via Google otherwise?
(Some people use a Windows virtual machine on their Mac to run AC only when they need to use the add-ons not available for Mac ... and then continue their work on the Mac side.)
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
