how to import autocad drwg into archicad
hi everyone.......actually i need 2 import autocad building plans into archicad all at same scale........can you help me out suggesting the methodology of importing the file...........so that i can directly create 3d view on that plans............
Here i explain how to import autocad drawing into archicad
- first of all you can select object.
- then save as with extension .3ds.
- Now you can go with 3d studio file export option and in that window you can select layer option.
- Then you can create a new empty drawing and use the 3DSin command.
- Then you can save the autocad drawing.
- Then In Archicad you can import the object.
