Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Overlapping lines and invisible entities in AutoCAD
How do I get rid of numerous overlapping entities, dots and invisible objects that appear in the drawing after importing from ArchiCAD?
I am using ArchiCAD 12 with AutoCAD 2007.
Early help appreciated.
Jothi
1 REPLY 1
Erika Epstein
The dots are from unloaded library parts.
As to overlapping fills and linework you can use the consolidation commands under
Edit>Reshape> Unify, fill consolidation & Linework consolidation. The help menu>archicad help will take you to the sections of the manual that will explain these.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
