When you write "I cannot use", what do you mean by "use"? Are you trying to manipulate them? Are you trying to move them? Modify their settings? What are you trying to do with them?
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac28
The fixtures are locked - I have to unlock them, This happens every time I open the file
and while they work fine during the session that I unlocked them in - it happens again when
I reload the file.
solution (of sorts)
It appears that some library parts, are used by Mep Modeler -- with a different icon, as long as I use them
as normal library parts they work fine - If they show a "cabinet" icon then they start looking for a mep modeler key .
Yes, these Library Parts are locked when the MEP Modeler is not loaded with ARCHICAD. This is normal behavior. I think you can unlock them, or unlock their Layer, I don't remember exactly which one. Then you will be able to edit/modify them.
