opening a 2d drafting from Archicad 16 in Archicad 14
hi !
I have to make some 2d draftings into Archicad 16, and then, somebody will use this draftings in Archicad 14.
It is possible to open a pln in Archicad 14 if that project was created in Archicad 16?
Thank you !
1 Reply 1
David Maudlin
anamarutza:
No. The 16 file would have to be saved as a 15 file, then that 15 file saved as a 14 file. Since 14 cannot recognize the new features in 16, it might make more sense to do all the work in 14. If all the work is only 2D, then you could save the 16 work in another file format (dwg, etc) that could be opened in 14.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
