please I need help!!!!
Hello everyone:
I'm desperate
I'm trying to import a 3d DWG file created in Archicad 11 to 3ds MAX, but at the moment that I import the file 3ds MAX changes all the elements from the model, it tears apart all the model into elements, how can I prevent that??
Please Anyone could help me????
Save As (export) as 3ds?
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
OR you can:
Apply scheme "as is for output" during exporting dwg.
The model would be just fine.
(don't forget to check the import settings in 3ds max, to be able to apply materials)
