problems with calculated length and quantities of beams
Hi all i'm a new user to AC and i'm having a problem with trying to get the summed amounts of beams in the schedules with different lengths[/img]
7 REPLIES 7
Add a "Ʃ" sign to the schedule field Lenght Right.
Thanks andro55 for your reply but putting the auto sum only gives me the total length of all the beams . what i'm after is a summarised total of the quantity of the same length/type beams with it's individual length in the same row
this is so i could order timber straight from the one schedule example
15 joists @ 5,000m
rather than 75,000m of joist
So you want this: 5 pieces of the same dimensions.
In the Schedule Fields panel, switch the positions of the Length Right and Quantity fields so that the Quantity field will be summed while the Length Right field is set not to be summed.
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen9 5900X CPU, 32 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, Ac20-Ac27
Loving Archicad since 1995
I will eventually get this but not quite yet
I think this is probably the closest you will be able to get with these Schedules.
There is no way of producing that exact "15 150x50 @5000" text in the Schedule itself, except possibly with the help of GDL Scripting.
oh well, at least now i know and can get on with my life. thanks for your help guys i'll be sure to come any other problems i'm certain to have
