4 weeks ago - last edited 4 weeks ago
Mep connection randomly is losing its properties and connections doesnt work. Archicad 25.
Anyone has idea how to fix this??
Its random once it works once it doesnt.
Actually tested 24,25,26 same thing happen in all of them.
PS. Clean install ver. nothing changed everything is out of the box
Edit:
Reasons its happening
1. If you use object and try to connect to other object of same type and u missplace connections and then try use the same object that was missplaced causes its connections being corrupted and it acts just like a "chair" not mep component
2. Sometimes its happening randomly for example i can start new project and paste 1 object use sample tool (alt key) and 1 of 5 times object is corupted.
3. there are others problems but harder to reproduce just like in the yt vid where not only object is connecting wrong but also if u try to connect pipe to vent element there isn even an errror. Not sure what is causing this tho.
Generally speaking sample tool is the problem for all of this. when using objects with clear state nothing wrong is happening
