property expression: show the ID belong to "from zone nr"-zone in door property....
Hello to everybody ,
I need a property expression, which will show the element-ID of the zone, which belongs to the door via "from zone number"-property.
I need the element-ID for matching the doors and zones in an existing FM-system-database... - so I have to get the ID and not the zone-number for door propertys "from-zone-number" and "to-zone-number".
If anybody of you have an idea, how to realise this challenge - PLEASE let me know...
...if you have a better solution than using 'property expressions' - I am open minded to any method, which can grab the expected values...
I really hope you can help me,
Best regards from Vienna,
Klaus
2 Replies 2
...in 'simple' SQL it would be something like:
SELECT 'element_id' FROM [zones] WHERE 'zone-number' = 'gs_zoneinside-number'
I hope this will describe a little better, what I need than my statement above ...
Best regards from rainy Vienna ,
Klaus
fuzzytnth3
There is a "Zone To" property
https://my.pcloud.com/publink/show?code=XZnU8HkZrG0t7fn3Abzy7cu5d0sbDpDMrOzX
Hope that helps
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
