Haneef Tayob
publish to PDF causes sheet to print
Any suggestions.
Sometimes, when I publish from plotmaker (windows version) to pdf, the pdf publishing lists as 'failed'. Then for some strange reason, we see that whatever we were trying to publish as a pdf file has printed out at our laser printer, all distorted.
I then have to manually print to the Amyuni pdf driver.
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
I have had the same problem, but resart AC9 and it seems to fix the problem
