artktecture
"Layer is not" is not excluding items from that layer in a schedule
I have a trash layer where I keep things I might need later and don't yet want to delete from the model. When trying to schedule the surface area of stone it keeps including areas from my trash layer yet I have the schedule set to exclude this layer. If I delete the items from the trash layer then my schedule is correct
Why is this happening?
artKtecture uses Archicad 24/Twinmotion
Lenovo Thinkpad | Xeon E2176M@2.70 GHz | 32GB | Quadro P4200 8GB
Oculus Rift S VR tours
Contour Rollermouse Red Plus (ditch your mouse and get one of these!)
Using a highly modified Shoegnome template (Thanks Shoegnome!)
3 Replies 3
runxel
Set your brackets accordingly.
As a rule of thumb: As soon you use an "OR" connection in your criteria YOU NEED to set brackets, otherwise your results will always be skewed.
As runexl suggested, your 3 composites need to be in brackets otherwise any element that meets the condition of the last 2 ORs will be included (first conditions OR any of the last ones).
Currently you are finding elements that meet these 3 criteria ... All Types and layer is not trash and composite is manufactured stone 1/2 ply OR any Composite that is 3" manufactured stone OR any composite that is gable end wall stone.
artktecture
Thanks! That worked great!
