‎2019-07-02 06:06 PM
Solved! Go to Solution.
‎2019-07-05 12:26 PM
gotphish001 wrote:Yes, you need a licence to be able to use MEP.
Do you need a license for the MEP add on. I found the library for that but it says no license found. I'm about to try and find the answer to that one on google.
‎2019-07-02 10:33 PM
‎2019-07-03 03:03 AM
gotphish001 wrote:When you install the add-on, it will install that 'Accessories' library into your Archicad program folder.
Another question. I downloaded all the goodies from GS. The accessories one says you need to put the accessory library into your project, but it doesn't say where to get it. So where is it or am I missing something?
‎2019-07-03 03:34 PM
