3 hours ago
Hello everyone,
I hope someone can point me in the right direction because I am currently stuck on a real project.
I am using Archicad 29 (standard license) with the native MEP Modeler.
While modeling the plumbing and fire protection systems, I noticed that the available Pipe Reference Set only includes diameters up to DN65 (75 × 4.7 mm).
For my project I need, at a minimum:
These pipe sizes are essential because I am coordinating all disciplines in BIM and need to perform clash detection. At the moment I cannot accurately verify whether the sanitary stacks and fire risers fit within the limited shaft space available.
After researching the documentation, I learned that Route Specifications appear to be available only in Archicad Collaborate, and this option does not exist in my installation.
My questions are:
I would appreciate any guidance, examples, or recommended workflows.
Thank you very much!
2 hours ago
Hello.
You need to configure and create your dimensions; this will standardize pipes, materials, transitions, elbows, and so on. There's no difference between Collaborate and the one you have (if it allows you to model MEP).
