4 weeks ago - last edited 4 weeks ago by Barry Kelly
I just recently started to use the stair headroom feature to visualize code required clearance. I notice that at the top of the stair the headroom extends horizontally across the top tread, which of course does note meet the IBC Building code, which requires the head room to extend to the top riser and over the top landing. Is there a setting that I am missing? The gray in my screenshot is archicad, the red line is code.
Operating system used: Mac Apple Silicon tahoe
4 weeks ago
Is it because your stair is set to end with a riser and not a tread?
So it is not taking into account the top tread which would be the landing.
4 weeks ago
Needs an option that carries the clearance box an extra riser, then extends it horizontally by a user defined amount?
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
4 weeks ago
yes, exactly. At a minimum the head room needs to extend one tread depth over the landing, but options such as: 3' over the landing, or an amount equal to the width of the stair, or a custom amount would be ideal
3 weeks ago
Settings similar to what is available in the Stair Support Connection options.
3 weeks ago
The whole headroom feature was never finished. We also miss the possibility to change the display (pen/fill/surface) of it.
I'm still hoping this will be picked up again, @James B (:
3 weeks ago
For the past 15 years I have been manually using line work to show stair head clearance so I like the automatic display but yes, I did immediately go searching for how to edit the color, transparency and pen to no avail. Since dark gray is the only option I just end up turning it off.
