scale off in DWG output to AutoCAD
I could use some help with this. I have an Archicad drawing, drawn at 1/4" scale, that I saved as a DWG file. The end user says that she works in Modelspace at 1/8", I believe she uses AutoCAD 2000. She says that the dwg file I send her is very small. What should be 18' for example scales on her computer as about 4 1/2".
What could I be doing wrong?
Also - she said everything seems to be grouped in a block and is difficult to edit.
I have been saving these from Archicad 9, from Plotmaker I just got Archicad 11 and have tried saving form there as well but the end result seems to be the same on her end.
Mac G4 OSX 10.4.10
Thanks
1 REPLY 1
Thomas Holm
Scale depends on the DWGUNIT that you set in your translator when exporting. The reciever must use the same unit or scale will be off, example 1 dwgunit = 1 ", or better, 1 dwgunit = 1 mm
However, I remember a bug in the AC9 dwgtranslator - it incorrecly didn't set the INSUNITS parameter to the same DWGUNIT. But I thought that affected only metric translations.
