sketchup questions
hello everyone ive just heard about this program and i wanted to ask sth
i need to know how can i create a 3d building for google earth. i want to build the public library in my city. can i do it in archicad? or i have to learn sketch up?
thanks a lot
5 Replies 5
Sketchup is as it's name implies, a sketching and conceptual design tool. You would need another software such as Archicad to develop the construction documents.
Rakela Raul
you can use either one.......easier / lighter in sketchup
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
David Larrew
In AC 11 you can use the "Google Earth Connections" Add-On to submit your AC model directly to Google Earth.
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Everything can be done without SketchUp using 11, as David says.
If you have AC 10 or earlier, you can still model in AC and then export as 3DS from the 3D window, and import the 3DS file into SketchUp for getting into Google Earth. (Since your question was "can I build this in AC".)
Karl
!!! thank you all !!!
very much!
