transfering autocad files to archicad
Every time i try to transfer a file from autocad into archicad, it comes up with "Archicad supports max 27+ 3 characters" and i am unable to open them?
I have a massive amount of file exchange to do and it would have been great if i could have been able to transpose these files without having to change the file name
5 REPLIES 5
Gerald Hoffman
Kevin,
Have you tried renaming the file to a shorter name first?
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-6000 USA
2019 MacBook Pro-macOS 15.0 (64GB w/ AMD Radeon Pro 5600M GPU)
why ArchiCAD still adhears to this archaic filename standard I have no idea....
Gerald Hoffman
Kevin,
Sorry, I didn't read the end of your post. I see you already know the solution but are just wondering why.
Gerald Hoffman
Kevin
If you have a very large number of files that need to be renamed, it can obviously be very tedious, if they can be named in some sort of series or logical pattern however (eg: file1.dwg, file2.dwg, file3.dwg....) then you could use a mass file renaming utility, search http://www.download.com for something like this.
HTH,
Dan
Edit: possibly something like this: FileName Magic Pro , I havent personally used it, but it might be worth a shot.
Thanks Guys,
Dan Magic Pro works a treat - Cheers
