Point Cloud - Troubleshooting Guide
Huge Point Clouds can't be opened in ARCHICAD
Affected version: 19 and later | Severity: workaround applicable | ID: 191641
Issue
Importing Point Clouds that result in a .lcf file larger than 4GB cannot be done because of the limitation of the .lcf extension. Importing such large files will freeze the import process.
Solution
Ask the provider of the Point Cloud file to reduce the resolution of the Point Cloud model (fewer points) or spli it into smaller parts.
Point Clouds are not displayed or displayed incorrectly in 2D/3D on Mac
Affected version: 19 and later | Severity: workaround applicable | ID: 178158
Issue
Imported Point Clouds are not visible in 2D/3D or are displayed in black in floorplans/sections/elevations/3D in case of some Video Cards (e.g. Intel HD 3000 and 4000, Intel Iris Pro)
Solution
Turn off the 2D and 3D Antialiasing in the Options - Work Environment - Advanced Redraw Options
Zoom problem on Floor Plan on Mac
Affected version: 19 and later | Severity: workaround applicable | ID: 182172 devTT139770
Issue
In some cases the display of a Point cloud on Floor Plan can be blurred
Solution
Rebuild or navigate (pan or zoom-in/out) the view. In certain cases, zoom-out will refresh the floor plan.
Good to know
It is not possible to place a Point Cloud via certain remote desktop applications
Issue
It is not possible to place/display a Point Cloud via remote desktop applications which does not support OpenGL 2.0. Already placed Point Clouds are also not visible on floor plan/section-elevation/3D,  if the ARCHICAD file is opened via non-OpenGL compatible remote desktop application.
Solution
Place the Point Cloud locally or use remote desktop application which supports OpenGL 2.0.
Floor plan display range
Issue
In some cases the Point Cloud is not visible on floor plan, even though it was imported to the Origin. The Point Cloud object is out of the floor plan cut plane display zone
Solution
The floor plan cut plane display zone can be overridden in the Point Cloud’s settings dialog.
Limitations
Browse more articles
Back to articles
