on 2019-03-12 11:00 AM - edited on 2021-11-19 11:09 AM by Rubia Torres
1. Select the translator you wish to edit.
2. In the Settings tab, navigate to the Save Options and click the Browse for template DXF/DWF file button.
3. Select the DWG/DXF file to map to and click Open.
4. The attributes in the selected file will now be available to select in the attribute mapping tabs.
