There is no need to mark your posts as solved (the green tick) until you get an answer that does solve it.
I have removed the tick for now (I have also done that for some of you other posts).
The CUTPOLY is not a polygon with a hole, it is just the hole.
So the first 5 lines can be deleted.
Then you define you elements.
Then end the cut.
It goes like this.
CUTPOLY
Element script (i.e. PRISM with those first five co-ordinates
CUTEND
Now you can mark this post as ‘solved’ if you understand what I mean.
