It will depend on what window objects you have but if you use the default Graphisoft ones then simply place two different windows at the corner.
Then in the settings find the controls for the corner and set them as you want.
Attached is a silly example - they wouldn't be different heights.
i.e. don't use the corner window tool as both windows will share the same settings except for length.
