DangCad1
Custom window - hole not the same shape as the window
I have created a custom window using slabs (File > Libraries and objects > Save Selection as > Window) (see screen 1)
The window turns out like I want it to - however, the window hole is rectangular, instead of being the same shape of the window. See screen 2 with settings for the window, can't find anywhere to change this. What did I miss in the process?
Screen Shot 2022-04-14 at 13.50.51.pngScreen Shot 2022-04-14 at 13.45.15.png
AC 28 / Apple M4 Pro 24 GB / OS Tahoe 26.3.1
1 Solution
a2o-architecten
Did you use a extra Slab or Roof tool to create another element whose contour matches the outer contour of the desired wall hole or wall niche? The element ID field should also be named to 'Wallhole'.
Try following workflow: https://help.Graphisoft.com/AC/25/INT/index.htm?rhcsh=1&rhnewwnd=0#t=_AC25_Help%2F040_ElementsVB%2F0...
Michel Janssens,
Project Architect, BIM Manager
a2o-architecten
https://www.a2o-architecten.be
ArchiCAD 8-27 NED FULL KME
Macbook M1 PRO
Go to post
1 Reply 1
a2o-architecten
Michel Janssens,
a2o-architecten
Macbook M1 PRO
