SOLVED!
GDL: Operators and Operands
Lingwisyer
Guru
Hi all,
Am I correct to assume that transformations between when a group is defined and when it is applied to another as an operator modify the location of it?
Ling.
1 ACCEPTED SOLUTION
Solution
Lingwisyer
Guru
It is so.
I was having troubles applying the transformations around where I am applying the operand in my head so it was not quite correlating... Could not get a simple PLACEGROUP to work to do it as my operand was in a sub-routine which causes issues as pointed out in this post by Péter Baksa.
I now have issues with positioning as the transformations prior to it's application vary depending on a few other parameters... Time to figure out how to rewrite my script to isolate the operation.
Ling.
1 REPLY 1
Solution
Lingwisyer
Guru
It is so.
Ling.
Learn and get certified!
