Horizontally slanted windows?
Hi!
Is it possible to make windows slanted horizontally, so that they do not have the same angle as the wall in plan?
Like in this sketched plan:
[/img]
1 REPLY 1
Yes but only if you use the polygon method for modelling the wall rather than a standard wall.
Then you can place and rotate the window with the pet palette option.
Learn and get certified!
