Interior Door sits outside of wall jamb when placed
dcerezo
Hey guys,
I've got this weird situation when trying to place a D24 object in my interior walls. When I place the door and it swings towards the side I picked as "exterior" it works fine. But if I flip the swing, away from the "exterior" side, it sits away from the jamb. I can't for the life of me figure out why.
Can someone help me identify the setting for this?
ArchiCAD 26 - iMac 27, Late 2019, 3.7 GHz Intel Core i5, 32GB Ram, Radeon Pro 8GB, macOS Sonoma
Minh Nguyen
Dear All,
I'm happy to announce that the first Library Update for Archicad 24 USA is available, which will address this issue. The package can be downloaded via the Check for Update function.
Please let me know if you have any problems with the update!
Thank you very much for your patience and understanding!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
27 REPLIES 27
Is it a Complex Profile Wall?
Is your door frame thickness = wall thickness?
Where is your Wall reference line?
Minh Nguyen
Thank you very much for sharing and I am very sorry about the issue!
Depend on the types of wall, there could be different reasons that might cause this. To help with the investigation, is it possible to share with us a sample PLA file that contains the same wall and door in the screenshot?
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
dcerezo
Braza wrote:
Is it a Complex Profile Wall? No, just pretty basic composite wall types.
Is your door frame thickness = wall thickness? Where is that setting? I don't see that.
Where is your Wall reference line? Center
dcerezo
Hello Minh,
Please see attached. Doors 2 & 3 and Doors 4 & 5 are identical as far as I can see. The only difference is the swing towards the exterior or interior side. If it swings towards the exterior side, it works fine...if it swings towards the interior side, it jumps away from the wall.
Here's a link: https://www.dropbox.com/s/zketi5lsb3x7ra8/Door%20Swing%20Issue.pln?dl=0
Hopefully you can figure it out.
Thanks!
Here:
Minh Nguyen
Thanks for the file! After some tests, I believe that this particular door is corrupted somehow. I compared its settings with the neighboring one and found nothing special. If I use Parameter Transfer to pickup parameters from the "good" door and inject them to the "bad" door, it should jump to the wall's face.
Please let me know if it helps!
Thank you very much!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
dcerezo
Braza wrote:
Here:
I don't have that option...that's weird.
dcerezo
Best regards,
Minh
Thank you Minh, I'll do that, not sure how the door got corrupted, but that does work.
That could be a USA versus INT library version.
In the AUS library (I believe is similar to the INT library) that door even has a different name (Door 24 versus D1 24).
