Need three-centered basket handle arch, segmental arch
Hmooslechner
I scripted a new GDL for an three-centered basket handle arch or an segmental arch, where all bricks are situated following the bricklayer-rules in Austria every time new, when you alter the hight or the length of the opening by handles.
If there are enough of You who would see some applicability, let me know here - then i will translate it - or would some one from You like to do this?
German vid - but You would get the idea anyway by turn off the tone:
https://www.youtube.com/watch?v=DvcqUFKDpns
To try out:
https://www.dropbox.com/s/subqk0lg61ey9x4/Korbbogen%20mit%203%20Mittelpunkten_MWK%20d.pln?dl=0
let me know..
4 REPLIES 4
sinceV6
Heimo
As usual... outstanding work. I really like how you tend to integrate the geometrical background that leads to the solution (the dashed lines in this case). The projected view when rotating upright looks quite sleek.
Regards.
Hmooslechner
some bugfixes - mortar between bricks on basket-arc:
tryout:
https://www.dropbox.com/s/zpxq3kvzdrzcqim/Korbbogen%20mit%203%20Mittelpunkten_MWK%20f.pln?dl=0
https://www.youtube.com/watch?v=jGuzJ78t39I
Hmooslechner
including Archicad profil-manager - profiles:
german but... turn off the sound..
https://www.youtube.com/watch?v=STeUGJqYmBU
https://www.dropbox.com/s/ozdqq023pl8it86/Korbbogen%20mit%203%20Mittelpunkten_MWK%20g.pln?dl=0
Hmooslechner
some improvements to my Arc-GDL:
Arc-forms: segmented or basket or straight 5/2018
brickwork: the bow-length is divided automatically - the keystone is always axially vertical.
running bond, english bond one brick thickness, english bond of one and a half bricks' thickness, hybrid forms in the basket ach..
mortar includet as Tube-command
added profilmanager-profile - types - so user editing is possible within the arch
NAME for Bimcomponents.com: "Arcs_segmeted_basket_straight with bricks and profiles"
https://www.dropbox.com/s/vlrj7h4bhwz86td/Arc-forms%20with%20bricks%20and%20profiles%20international.pln?dl=0
and Youtube-tutorial:
https://www.youtube.com/watch?v=P5R11hvS-a0
