Design forum
SECTION VISIBILITY: Displaying only certain element of the same layer
Johann_P
I have a section which shows multiple open web steel joists.
Part of the building is at an angle with the section cut plane, thus multiple joists are visible making it look incorrect (even though it practically is correct)
I would like to only show one of the joists so the webs of the joists at the rear are not visible.
There are other joists on the same layer that is at 90° with the section and looks correct.
Is there a way to hide some of the elements on a particular layer?
So only 1 joist is visible in portion B of the drawing while still showing all the joists in portion A
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
1 REPLY 1
Marc H
Limit the depth of the section view? Or, set some of the joists’ appearance light gray or white with a GOR?
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC25 USA on 16” MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) + 2 Asus ProArt PAU32C (4K)
Didn't find the answer? Start a new discussion
