Design forum
request story_name as value
Fredrik Castilla
I´m buliding a simple 2D-object
Is it possible to use:
n= REQUEST ("Story", "", index, story_name)
and let the requested ”story-name” generate a parameter text value ?
I´ve succeded with having the ”value” show with richtext, but I want to be able to schedule the object and the story_name value.
Mac, Archicad 20-22
1 ACCEPTED SOLUTION
Solution
you can use the other requests in parameter script:
n = REQUEST ("Home_story", "", index, story_name)
n = REQUEST ("Story_info", expr, nStories, index1, name1, elev1, height1 [, index2, name2, ...])
Piotr
3 REPLIES 3
Solution
Piotr
Fredrik Castilla
Thanks! it works!
What´s the difference?
Mac, Archicad 20-22
The one You tried to use is just listing the "visible" story not the story that is the current story of the object..
Piotr
Didn't find the answer? Start a new discussion
Labels
