request story_name as value
I“m buliding a simple 2D-object
Is it possible to use:
n= REQUEST ("Story", "", index, story_name)
and let the requested ā€story-nameā€ generate a parameter text value ?
IĀ“ve succeded with having the ā€valueā€ show with richtext, but I want to be able to schedule the object and the story_name value.
you can use the other requests in parameter script:
n = REQUEST ("Home_story", "", index, story_name)
n = REQUEST ("Story_info", expr, nStories, index1, name1, elev1, height1 [, index2, name2, ...])
Piotr
Piotr
Thanks! it works!
What“s the difference?
The one You tried to use is just listing the "visible" story not the story that is the current story of the object..
Piotr
