2014-04-10 02:51 PM
2014-04-12 12:27 AM
AndorSzamos wrote:We use Boost with the ArchiCAD API, but haven't seen any compiler warnings/errors. What warnings are you seeing?
I would like to use a library like Boost, but it has warnings, and my compiler gives me C2220(warning treated as error) messages. Can you recommend any good libraries such as Boost (->CGAL) which could work with the current settings of ArchiCAD, or is it recommended to simply modify the warning level in Visual Studio?
