2021-11-16 04:45 PM
Hello Everyone,
I'm looking for a way to use the Python Wrapper to automaticly export the Attributes and Properties from their respective Manager. There is a function Built-In in Archicad, but we are wondering if there is a way to do it with the Python Wrapper (currently we have to export 4 tables, every single one manually in Archicad and we want to find a One-Click-Solution).
Thanks in advance
Dear Regards
Ziyad Nuwayhid
Solved! Go to Solution.
2021-11-16 08:22 PM
You did not identify which attribute tables you are interested in? However, YES, Python can download attribute lists. But you would only get a raw non-formatted list You would then, in Python, have to format and export it to some readable form such as Excel, XML, or JSon, This is only to get it into a readable form for you, if this is what you are after. i believe that the programming and manual use of a Python script for this purpose would be more trouble then what you are presently doing. The Python API does not have access to any table save commands directly.
