Archicad C++ API
Avoid frame around palette buttons
gehairing
Hello everybody,
I have an Archicad plugin that contains a small toolbar.
For this toolbar i use the classic 'GDLG' dialog definition.
By default this makes framed buttons.
What should i do to avoid having these frames around my icons ?
Thanks,
Georges
Viktor Kovacs
Use the noFrame flag in your grc file. For example:
/* [  3] */ IconButton            325    2   23   23    32100 noFrame
/* [  4] */ IconButton            350    2   23   23    32101 noFrame
Viktor Kovacs
Thanks a lot Viktor 🙂
