Archicad C++ API
Beam and column end cuts
abrakadabra
How can I access to information below from API?  I would need the angle of end cuts in case of beam and column.
I was not able to identify in the API_​BeamType nor in API_​ColumnType nor in the memo.
Regards,
Zsolt
abrakadabra
I have found it in  API_ElementMemo.API_​AssemblySegmentCutData[0].customAngle and API_ElementMemo.API_​AssemblySegmentCutData[0].cutType
Regards,
1 REPLY 1
abrakadabra
Regards,
