Archicad C++ API
Convert GS::UniString to char*
Docmatic
Hi guys,  I am tryng to use curl_lib in my Archicad Addon.   How can I convert a GS::Unistring to  char*
Thank you
Miha Nahtigal
const char* cString = gsUniString.ToCStr().Get();
BIMquants.comBETA - Quantities and Costs Estimation with Archicad AddOn :: rushing to publish a beta preview
Miklos Vegh
You should not instantiate a pointer with the result of ustr.ToCStr().Get().
The ToCStr() returns a CStr object which is created on the stack. When the next statement is executed the CStr object will be destroyed resulting an invalid pointer.
Use .ToCStr().Get() in function parameters only.
If you want to have a pointer use ustr.CopyUTF8 ()  instead, which returns a pointer to a newly allocated copy. This needs to be freed with delete[].
