GDL
Custom elements in Furniture Layout
Is there a way to use custom chairs and tables in furniture layouts (Dining Table Round / Rectangle etc)? I understand, a custom table would be a bit troublesome, but a custom chair should be easy to do.
You could try the new Param-o tool to create your own furniture layouts.
Here is a video of what you can do with regular Archicad objects and Param-o.
1 REPLY 1
