GDL
Fetch data from Polygon Count add on ?
MF BIM
Hello everybody šŸ™‚
Simple question, is there way to get data from the Polygon Count addon ?
Let's say I have a libpart that has too many triangles, could I somehow use that addon to check the count and reduce the resol ? Otherwise, is there a way to calculate that count ?
https://mfbim.fr | https://youtube.com/@mfbim
AC21 FRA 3005 - AC24 FRA 7600 - AC26 FRA 4027 | MacBook M1 Pro
There is no way to get it from GDL and iterate the model, 3D generation is a one-step process.
If you are using resol (or toler or radius) in your code then you can calculate or estimate the polygon count.
PĆ©ter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
4 REPLIES 4
Not sure if I understood your questions - but here goes:
"...could I somehow use that addon to check the count..."
Yes, this is exactly what PolyCount does
"...and reduce the resol?"
No, not reduce the resolution/triangle count using the PolyCount add-on - this you would have to do separately, either by editing the object directly or creating a new object.
"Otherwise, is there a way to calculate that count?"
Not sure what it is you want to calculate?
Erik Bjornhage : SwedishChef, ETTELVA Arkitekter, Gothenburg, Sweden
Architect : Digital Development : Graphisoft Cert. BIM-Manager
ETTELVA Arkitekter : Eriks LinkedIn
DELL Precision 5570; i7-12700H; 64 GB; RTX A2000 [8GB] : AC12 - future
Hello @Erik Bjornhage ,
Thanks for replying. What I meant is when creating a GDL object, is there a way to know or calculate to polygon count in the object at any given moment. That's why I was wondering if somehow there was a way to get the data from that addon directly into my GDL objects.
PĆ©ter Baksa
Thanks
Then I understand, but can't add any more to the discussion unfortunately. I still need to take the time to get into GDL šŸ˜ž
Peter seems to have a good answer for you below.
