Archicad C++ API
How do I get/set profile modifier?
arad
I am using Archicad 23.
I want to get the settings from favorites, but I can't get the values of profile modifier.
How can I get/set the value of all or a specific profile modifier?
Please, help me.
Here is the code.
GSErrCode favtest() {
	GSErrCode err = NoError;
	API_Favorite fav = {};
	fav.memo.New();
	fav.name = "test";
	ACAPI_Favorite_Get(&fav);
	ACAPI_CallUndoableCommand("place element from favorite",
		[&]() -> GSErrCode {
			API_Element elem = fav.element;
			err = ACAPI_Element_Create(&elem, &fav.memo.Get());
			if (err != NoError) {
				ACAPI_WriteReport(ErrID_To_Name(err), true);
			ACAPI_DisposeElemMemoHdls(&fav.memo.Get());
			return NoError;
	return NoError;
Ben Cohen
Hi Arad
I think this is a bug / limitation. I came across this same issue years ago in v22, and it is still not working in v24.. Profile modifiers in favourites are not set when using the API..
I ended up just setting the modifiers manually using "ACAPI_Element_SetProperty"
The Property_Test example is a good place to start if you go down that route.
Hope this Helps..
Ben Cohen
Mac and PC
Archicad (Latest Version) aus
www.4DLibrary.com.au
Hi, Ben.
Thank you for your reply.
I see.
I will try with your method.
I hope we can use it soon.
Thanks for the help.
