Developer forum
How to open a PDF file using API
Hi everyone,
Please help me any idea or API command to open an external PDF file in Add-on folder using ArchiCAD API.
Thanks. Regards.
Tibor Lorantfy
What is your goal with the PDF?
Do you want to place the PDF as a drawing into your project? Or you need only the text content of the PDF?
Hi Tibor,
I just want to open the manual pdf of tool via system default "PDF Viewer" software which is installed together with Apx and put in help folder. Thank you.
I am pleased with any suggestions. Thank you.
