Developer forum
Moving Hotspots
John Edmundson
Does anyone know if there is a limit to the number of movable hotspots nodes that can be defined in the 2D code for an object. It seems that I can only get 12 to work, anything past that and they stay frozen in there position. Thanks
No, I cant see how there would be a limit. I have objects that contain multiple customisable profiles in a single placed instance all defined using movable hotspots. I would say conservatively that I could have over 40 moveable hotspots in a single instance.
Check the hotspot ID as I have often discovered, when first creating moveable hotspots, some weren't moveable because of a clumsy ID error.
use the unID count method to be sure:
unID = 1
hotspot2 -a*.5,			.03, unID, lft_fixdpan_wdth, 1+128:	unID = unID +1
hotspot2 -a*.5+lft_fixdpan_wdth,.03, unID, lft_fixdpan_wdth, 2:	unID = unID +1
hotspot2 -a,			.03, unID, lft_fixdpan_wdth, 3:	unID = unID +1
Creator of Cadswift's parametric GDL libraries
Creator of Infinite Openings and Component Catalogues
Push the envelope & watch it bend
website: https://cadswift.com.au/
YouTube: https://www.youtube.com/user/CADSwift/playlists
John Edmundson
Thanks. The 3D code works fine but the 2D is where I am having a problem. I think I will rework the 2D code again.
