Developer forum
My StoreDictPolygon attempt
Pertti P__sky
Hi GS!
I'm glad to see the new DICTIONARY parameters.
The polygon operations have been able to operate with those since v23.
My little study of replacing polyline parameters with dict ones succeeded, but there was something with the StoreDictPolygon I can´t fire up. The attached object clips polyline with polygon. However It´s "usedictpolygon" -option gives an error message. The old way works fine.
So if there is an example of filling StoreDictPolygon properly I would be very pleased. I went through the GDL manual and some macros like openingsymbol_m.gsm but couldn´t find any help.
thanks
- AC-24 FIN - WIN 10 - HP Zbook -
“A winner is just a loser who tried one more time.”
George M. Moore, Jr.
Pertti P__sky
Ok, I found the solution: the coordinate values must be floating values, not integers as I had.
Pertti P__sky
Sorry @Pertti P__sky , can you share a small example?
because I'm struggling with the dict from a couple of weeks and I can't understand where I'm doing wrong...
Many thanks in advance!
