go
squall_tmo
since ‎2017-06-18
‎2026-10-09
User Statistics
  • 54 Posts
  • 0 Solutions
  • 13 Likes given
  • 2 Likes received
User activity
Hi, When I try to convert an object into a MEP Element (quite hidden in the standard Work Environments, since it seems to me like it only appear when you right click with a MEP object selected), it moves to the bottom of the visualization order. I even noticed (but I don't k...
Hi, From AC27 it seems like it's not possible to use the "Create Openings from selection" function with MEP Elements anymore. Am I wrong somewhere? Thanks
Hi, I'm trying to figure out how PolyOperation works with DICT......but anytime I try my result is always empty or an error... Does anyone know how this works?where can I find a small example? Many thanks in advance!
Hi, I'm trying to export an IFC file to a cost-estimation software. I'd like to keep elements geometry, to ease filtering elements by ARCHICAD Properties, but when I do this way Component quantities are listed like "Component1.Projected Area...", "Component1. Volume...", "Co...
Hi, I've got an unexpected problem that I don't know how to solve: In ARCHICAD 20 and 21 it was possible to export properties to excel and import them back to the project's elements, but I tried to do the same in ARCHICAD 22 and it can only import String properties: numbers ...
