Archicad C++ API
Problem printing doubles
Hello
I’m printing variables using acapi_writereport..
Today I just couldn’t print doubles. Whenever I print a double (using %d), it just gives me huge random numbers.. not even doubles (without . In the number)
For testint I even tried to set double t=0.1 and then to print it, it was still a huge number.. it used to be fine so all I can guess is to delete cache files/refresh things or something like this..
Thanks..
Akos Somorjai
%d is for printing integers, please use %g or %f for that. You can even specify the number of decimals (2 in this example): %5.2f
Best, Akos
Akos Somorjai
Best, Akos
Thanks.. Is there a document that sums those things up? Maybe a guide on the best way to debug?
Erenford
just do a web search for "printf format"
https://en.wikipedia.org/wiki/Printf_format_string
http://www.cplusplus.com/reference/cstdio/printf/
Archicad 25 5010 INT FULL
Archicad 26 5002 INT FULL
Visual Studio Professional 2019
Win 10 Pro 64-bit
