2019-11-14
08:47 AM
- last edited on
2022-09-29
12:58 AM
by
Daniel Kassai
import os import sys import re import xlrd excelFileName = "LayoutBook.xls" excelFilePath = os.path.join (os.path.dirname (sys.argv[0]), excelFileName) if os.path.isfile (excelFilePath) is False: sys.exit ("File does not exists: {}".format (excelFilePath)) xl_workbook = xlrd.open_workbook(excelFilePath) xl_sheet = xl_workbook.sheet_by_index(0) layoutTree = GetNavigatorTree (API_LayoutMap) subSetTree = [(list(layoutTree)[0], 0)] def GetItemsFromTree (tree, typeSet = None): l = [] for k in tree.keys(): if typeSet is None or k.itemType in typeSet: l.append (k) l.extend (GetItemsFromTree (tree, typeSet)) return l masters = GetItemsFromTree (layoutTree, {API_MasterLayoutNavItem}) def GetChildrenFromTree (tree, subSetTree): if not subSetTree: return list(tree.keys()) for k in tree.keys(): if k.name == subSetTree[0][0].name and k.uiId == subSetTree[0][0].uiId: return GetChildrenFromTree (tree, subSetTree[1:]) return [] def FindItemByName (items, name): for item in items: if item.name == name: return item PrintError('Bad Name: {}'.format(name)) return None def FindItemByIDName (items, ID, name): for item in items: if item.name == name and item.uiId == ID: return item return None def CreateSubSetItem (ID, name, parent): newSubSet = APIObject () newSubSet.uiId = ID newSubSet.customUiId = True newSubSet.name = name newSubSet.customName = True newSubSet.itemType = API_SubSetNavItem newSubSet.mapId = API_LayoutMap CreateNavigatorItem (newSubSet, parent) return newSubSet def CreateOrChangeLayoutItem (ID, name, masterName, parent, oldItem = None): newLayout = APIObject () if oldItem is None else oldItem newLayout.uiId = ID newLayout.customUiId = True newLayout.name = name newLayout.customName = True newLayout.itemType = API_LayoutNavItem newLayout.mapId = API_LayoutMap newLayout.db = APIObject () newLayout.db.typeID = APIWind_LayoutID masterLayoutItem = FindItemByName (masters, masterName) newLayout.db.masterLayoutUnId = masterLayoutItem.db.databaseUnId if oldItem is None: parentChildren = GetChildrenFromTree (layoutTree, subSetTree) if not parentChildren: CreateNavigatorItem (newLayout, parent) else: CreateNavigatorItem (newLayout, parent, parentChildren[-1]) else: ChangeNavigatorItem (newLayout) return newLayout def GetParent (actIndex): global subSetTree for i in reversed(range(1,len(subSetTree))): if subSetTree[1] >= actIndex: del subSetTree return subSetTree[-1][0] newSubSetNumber, newLayoutNumber = 0, 0 for row_idx in range(1, xl_sheet.nrows): for column_idx in range(1, xl_sheet.ncols): idCell = xl_sheet.cell(row_idx, column_idx) if idCell.value != '': ID = idCell.value.strip() NAME = xl_sheet.cell(row_idx, column_idx + 1).value.strip() MASTER_NAME = xl_sheet.cell(row_idx, column_idx + 3).value.strip() PARENT = GetParent(column_idx) oldItem = FindItemByIDName (GetChildrenFromTree (layoutTree, subSetTree), ID, NAME) if MASTER_NAME == '': newSubSetNumber += 1 if oldItem is None: subSetTree.append((CreateSubSetItem (ID, NAME, PARENT), column_idx)) else: subSetTree.append((oldItem, column_idx)) else: newLayoutNumber += 1 CreateOrChangeLayoutItem (ID, NAME, MASTER_NAME, PARENT, oldItem) layoutTree = GetNavigatorTree (API_LayoutMap) break print("Created {} subsets and {} layouts based on {}".format(newSubSetNumber, newLayoutNumber, excelFileName))
2019-11-14 11:29 AM
