GDL
Wallniche with arch
stefanonodari
Hi guys,
I'm scripting a wallniche with arch.
I have a problem with vertical line of one edge that is invisible (in the picture are in red).
I want that the edge that connect the two arch (in the picture are in blue) are invisible.
I attach a 3d image and the script of the object.
1 REPLY 1
This aspect is controlled by the mask codes for each point.
Instead of "15+16" use "13+16".
Creator of Cadswift's parametric GDL libraries
Creator of Infinite Openings and Component Catalogues
Push the envelope & watch it bend
website: https://cadswift.com.au/
YouTube: https://www.youtube.com/user/CADSwift/playlists
