Hmooslechner
Dividing polygons into equal distances - maybe for chains or Brick-Arches
Dividing polygons into equal distances: https://www.youtube.com/watch?v=zjISXrDNG28
(This forum don't let me post the vid, because it thinks its private - but its not.. kind of strange..)
This post is a additional answer to: https://community.graphisoft.com/t5/Developer-forum/Using-GDL-to-write-parameterized-iron-chains/m-p...  (here ist "read only for me" - as if there is one single solution enough..)
My new solution is not a mathematical approach, but a solution that should work with any possible polygon...
Check and test - reply!  AC26EduAut..
https://www.dropbox.com/scl/fi/2ujgl80rxcsc5syd20c25/Gleiche-Abst-nde-entlang-einer-senkrechten-Para...
hevi
Ace
Good and interesting work - as always. The approach has the intuitiveness and efficiency we need when modelling in AC and should really be provided by a native tool for dynamic arrays/sequences.
Hmooslechner
What something like this can lead You to also:  Insulation-Line - dividings of polygones:
AC26EduAut:
https://www.dropbox.com/scl/fi/tqcgnl1whdvpag7hqnfk1/Mehrfarblinie-H26.pln?rlkey=t9vy6qw6vperjc5820m...
https://www.youtube.com/watch?v=iinDQeamu0Y
