Thursday
HI
I am an old Autocad user. The tools for drafting 2D lines, circles and so on are quite different in Archicad. Are there any good video tutorials that you can recomend that gives a good set of tips an tricks on how to use the tools the best way for efficient drafting in 2D?
If you have a link to a youtube video please let us know.
Thanks in advance 🙂
Friday
Archicad is not a 2D drawing package.
Most of the '2D' drawings you need are automatically generated from views of the 3D model.
They are really just for adding a little extra annotation to a view.
The Help > reference manual will explain the tools.
If you are trying to create fully 2D documentation without a 3D model, then Archicad is the wrong software.
Friday
Hi @Steffen,
If you like to use Archicad for 2D drafting I can tell you that it’s the best choice (IMHO) with all respect to Barry’s opinion.
Archicad is much easier for drafting than AutoCAD & many other drafting software.
For sorry, you won’t find this sort of YouTube videos but rather you can find 3D modeling & documentation ones.
The only solution for that is to use the help guide which will comprehensively describe all 2D tools, pen sets & colors, layers, favorites & how to publish/print your drawings as DWG/PDF.
Saturday - last edited Saturday
i have made several tutorials in german for 2D-Drafting but if You aren't able to use german, its not very useful to link it here for You. The first thing to consider in 2D is to use some keyboard shortcuts - not much -about 10 are suficiant enough for speed-drafting. Also very important is to know the three ways to set the vector-coordinates in drawing, the use of the automatic helplines and to notice the mouse-curser reactions on given elements. Use more hatches than lines in drawing. Know the hatch-editing commands - then you speedup drawing much faster than in Autocad. Know the function of Alt+Klick and CMD+Click. and so on. Knowing all this, You also speedup Your drawing-Skills in 3D - its the same.
Beginners:
https://www.youtube.com/watch?v=Q59anKABMMs
https://www.youtube.com/watch?v=1S3PAhKaGFQ
Shorts:
https://www.youtube.com/watch?v=XYasTnopPsI
https://www.youtube.com/watch?v=AAiVhUtRtCs
https://www.youtube.com/watch?v=s8Z_K-7DDwY
https://www.youtube.com/watch?v=Ec5iwK45yUA
https://www.youtube.com/watch?v=qRGKHWejLfo
https://www.youtube.com/watch?v=O8z4XKJXcgs
Saturday
Thank you very much !
I will look into these videos. I understand German.
Yes shortcuts i need to develope. It like playing piano. I have to learn a new instrument after 30 years with autocad 🙂
Maybe use my old ones, bit they interfer with the standard ones in archicad.
Is there a command for "repeat last command" ? In autocad I used Space for this. Very handy
Saturday
Why are the shortcuts in Archicad so complicated? These are the ones i use in Autocad Just one push
c = circle
ctrl+c = circle copy
l = line
p = polyline
o= offset
ctrl+o = offset copy
f=fill
d = drag
ctrl+d = drag copy
r= rotate
ctrl+r = rotate a copy
Saturday
You can change them in the settings.
Saturday
As @Hmooslechner said, you can change shortcuts in the Work Environment (be sure to save those settings with a name… and export to your file system in case you need to re-import them later due to reinstalling, or making a change that you regret).
But, seriously, it is not reasonable to change to a different manufacturer’s software and expect the shortcuts of another. For example, Adobe does not use the same shortcuts as Microsoft, Etc, yet, if it helps you transition, Archicad lets you customize shortcuts, menus and more in the Work Environment panels.
Saturday
You are right I suppose. I have to practice and learn the new way 🙂
Saturday
I recall that, when I was first contemplating using Archicad, I was also quite concerned about how drafting would work, since everything seemed so radically different.
As you learn Archicad, you will get used to the 2D tools but, if you're using the software correctly, you will also need to use those tools much less. The best advice I can give you — something I learned from the stalwarts on this forum — is to model it as you would build it. Stop giving primary importance to the drawing output (like you do in AutoCAD) and, instead, think about creating an accurate virtual model. The drawings will follow…
