‎2013-07-22
02:27 AM
‎2025-02-07
01:57 PM
Aruzhan Ilaikova
‎2013-07-22 01:19 PM
‎2013-07-22 04:26 PM
‎2013-07-22 04:44 PM
‎2013-07-22 05:53 PM
‎2013-07-22 06:04 PM
‎2013-07-22 06:20 PM
‎2013-07-22 06:31 PM
outpostarc wrote:
Make sure you're saving the pen set correctly by going to Options - element attributes - pens and colors. Pen an existing set and make the changes to pen sizes and then store as 'whatever name you want'. On your layout select the drawing window and open the setting dialog box and make sure the pen set for that window is the one you created. Make sure in the view menu you have the true line weights set to show.
Hope that helps
‎2013-07-22 06:48 PM
Hope that helps
‎2013-07-22 07:05 PM
