3D materials/Texures
Miner
Does anyone have a good source for getting additional modeling textures to add to Archicad?  I've looked at BIMcomponets.com and found that to be very limited in selection.  And many occasions that link doesn't work anyways.
Archicad 28 Solo
iMac 27" 3.8GHz i7
8GB RAM
4 REPLIES 4
Miha_M
If you are on a SSA subscription (or whatever it is called now), you can get additional textures.
Additional Surface Catalog for SSA Users - Graphisoft Community
| Archicad 4.55 - 27
Miner
Thanks!  Found some more useful texture doing that.
Archicad 28 Solo
iMac 27" 3.8GHz i7
8GB RAM
DGSketcher
Legend
@Miner Do you know AC has a built in catalog of additional surface textures?
Go to Options > Element attributes > Surfaces, then Select "New" and then "New from catalog" and you can search for a range of surfaces that aren't used in the default Building Materials.
Gerry Leonor
you can also use ArchiTextures:
Create — Architextures
it's quite a powerful tool/site to use.
AC25 | Win10 | 64Gb RAM | Intel i7 13700F | RTX 4070 Ti
https://discord.gg/XGHjyvutt8
