2022-02-21 07:09 PM
Does anyone have a good source for getting additional modeling textures to add to Archicad? I've looked at BIMcomponets.com and found that to be very limited in selection. And many occasions that link doesn't work anyways.
2022-02-21 08:24 PM
If you are on a SSA subscription (or whatever it is called now), you can get additional textures.
Additional Surface Catalog for SSA Users - Graphisoft Community
| Archicad 4.5 - 29
2022-02-21 09:59 PM
Thanks! Found some more useful texture doing that.
2022-02-21 10:45 PM
@Miner Do you know AC has a built in catalog of additional surface textures?
Go to Options > Element attributes > Surfaces, then Select "New" and then "New from catalog" and you can search for a range of surfaces that aren't used in the default Building Materials.
2022-02-22 02:57 AM
you can also use ArchiTextures:
Create — Architextures
it's quite a powerful tool/site to use.
